I’ve got a small but annoying problem with an AC2.
It’s not visible in WinBox Refresh. No errors, just doesn’t find it. Always worked before.
Router OS is 6.44rc1, think it started with 6.44 beta (66 or 75 not sure).
The host is Windows 10 Pro 64 bit.
I just connected up an hAP AC (not AC2) - upgraded it to same 6.44rc1 - WinBox Refresh does find it.
I also checked
/tool mac-server print
allowed-interface-list: LAN
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=mactel
add name=mac-winbox
add comment=defconf interface=ether1-out list=WAN
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add bridge=bridge comment=defconf interface=wlan2
Windows with WinBox is connected to ether2.
I am able to connect ( to the AC2 ) if I type in the IP ( 192.168.88.1 ) manually.
It’s not Windows Firewall - 1) have tried switching it off, no difference 2) WinBox Refresh does find the hAP AC (not AC2) just fine even with Windows Firewall enabled.
Any ideas?
