access CCTV from outside
I have this setup, Linksys-mikrotik-cctv , I can access CCTV using our local network by going to http://192.168.2.19 ,my mikrotik act as the dhcp server for our lan and it gets the ip 192.168.1.25 from linksys, I want to access it using my wan ip/ dynamic host name from outside, thanks.
my solution is Mikrotik — linksys —cctv
setup/config your linksys as lan static ip and now disable your linksys wan port and connect to lan port
if you wish to access your cctv from outside use mik VPN or nat forward and define your cctv port use
my english is bad sorry
thanks
