I have mikrotik RB750GL router with one LAN 192.168.2.0/24. The router LAN port is further connected to swtich and all computers are connected with that swtich and gets dhcp ip from LAN 192.168.2.0/24.
I have two CCTV DVR connected to same switch with different IP address 192.168.1.100 and 192.168.1.200
The problem is I cannot access DVR from client computer 192.168.2.50. So please guide how can I achieve this?
The easiest way would be to move your DVRs into the same subnet as the rest of your gear is.
If this is not possible for any reason, give your router another IP address (i.e. 192.168.1.1/24) on the LAN-facing interface.
Make sure the DVRs use this IP as default gateway.
Then packets can and will be routed.
Thanks Chris. By assigning additional IP address to router LAN interface the router started pinging 192.168.1.0/24 network but still I cannot ping from my laptop having IP 192.168.2.50.
