I have an RB153 (3.30 ROS, having issue getting to 4.16) > Connected to Bridged DSL Modem >
Ether1) WAN PPOE (Public IP - Dynamic > connected to the DSL modem)
Ether2) IP pool 10.10.10.1/24 > DHCP Server .100-199
Ehter3) IP pool 10.10.11.1/24 > DHCP Server .100-199
Ether4) IP Pool 10.10.12.1/24 > DHCP Server .100-199
Ether5) IP Pool 10.10.13.1/24 > DHCP Server .100-199 (PC with Fedora 14, LAN 10.10.13.99 > Need to allow Remote Access to PC from Internet)
WLAN1) IP Pool 10.10.15.1/24 > Hotspot
I just need to allow access to the linux PC for some software installation. (wish I knew more about linux as GoToMyPC or realvnc would be real handy right now)
Having trouble setting it up properly without FUBARing it completely. I do better with Winbox than I do Terminal Command line.
Here is what I was starting with: (not sure how to make this work with a dynamic assigned IP)
/ip address add address=*WAN DSL IP (DHCP)* interface=Ehter1
/ip firewall nat add chain=dstnat dst-address=*WAN DSL IP (DHCP)* action=dst-nat \to-addresses=10.10.13.99
/ip firewall nat add chain=srcnat src-address=10.10.13.99 action=src-nat \to-addresses=*WAN DSL IP (DHCP-Server)*
I was thinking maybe a simple port mapping, but was unsure if that would allow for full access to the PC with Fedora. Considering I am not finding a Remote Access application that works on Linux reliably. The following seemed better suited to allowing access to a Web Server application running on the PC as opposed to full access.
/ip firewall nat add chain=dstnat dst-port=8080 action=dst-nat protocol=tcp to-address=10.10.13.99 to-port=80
In trying to do this I have broken or changed the Firewall function of blocking repeated ftp and admin access to the router. I am really needing a hand to fix this, as soon as, someone can help.
Thanks,
