Access from RouterOS to switch1_cpu interface
Hello, I think it’s a common question, but I can’t find the answer.
How I can access to switch1_cpu port on RouterOS side?
I tried to add /if eth sw vlan:
[admin@MikroTik] /interface ethernet switch> vlan print
#   SWITCH                    VLAN-ID PORTS
 0   switch1                         3 ether1-gateway
                                       switch1_cpu
 1   switch1                         4 ether1-gateway
                                       ether2-master-local
                                       ether3-slave-local
 2   switch1                       200 ether1-gateway
                                       ether3-slave-local
                                       switch1_cpu
[admin@MikroTik] /interface ethernet switch> /interface vlan pr
Flags: X - disabled, R - running, S - slave
 #    NAME               MTU ARP        VLAN-ID INTERFACE
 0 R  vl_gw_3           1500 enabled          3 ether1-gateway
 1 R  vl_gw_200         1500 enabled        200 ether1-gateway
/ip addr pr
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.88.1/24    192.168.88.0    bridge-local
 1 D 192.168.6.16/24    192.168.6.0     vl_gw_3
 2 D 192.168.99.243/24  192.168.99.0    vl_gw_200
pings from routerboard to 192.168.99.1 (on vl_gw_200) are ok
from client connected on eth3 it’s are also ok
but I can’t access from the client (eth3) to the routerboard on 192.168.99.243.
I know why: this address assigned to vlan iface on ether1-gateway iface.
How I can setup VLAN interface on switch1_cpu port? Is it possible?
RB75x RouterOS 5.19, 6.0rc13
sorry my english
