Hi, I’m trying to confiigure mikrotik as it presented in the network diagram below.
I’ve already managed some of the main setting but there are a few I’m stuck with.
- L2TP+IPSec tunnel between Main Office and Office2 with access to local networks behind routers. - Done
- WireGuard interface (wg-snet) to access Main Office and Office2 local networks ONLY (without tunneling other data) for the remote user (WG SNET USER). - Partitialy done, I have access to Main Office local network but can’t connect to Office2.
- WireGuard interface (wg-vpn) for tunneling all data through Main Office WAN ONLY (without access to local networks) for the remote user (WG VPN USER). - Done
- Access to MT1 from specific WG SNET USER. - Done
- Access to MT2 from specific WG SNET USER.
- Isolate WG peers from each other. - Done
So looks L2TP+IPSec tunnel and WG interfaces are working well and the main problem is connecting to Office2 local network from WG SNET USER. I would really appreciate if you could help me with it.
You can find MT1, MT2 and WG peers configs below.
MT1
2024-01-07 15:08:06 by RouterOS 7.11.2
software id = 38WX-HX7F
model = RBD52G-5HacD2HnD
serial number = XXXXXXXXXX
add admin-mac=48:XX:XX:XX:XX:1B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] comment=d
/interface l2tp-server
add comment=snet name=l2tp-in1 user=snet
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
country=xxx disabled=no distance=indoors frequency=auto installation=
indoor mode=ap-bridge ssid=mainoffice wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX
indoor mode=ap-bridge ssid=mainoff1ce wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes comment=isp disabled=no interface=ether1 name=
pppoe-out1 use-peer-dns=yes user=v41701542
/interface wireguard
add listen-port=22522 mtu=1420 name=wg-snet
add listen-port=13531 mtu=1420 name=wg-vpn
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=l2tp_pool ranges=10.10.5.1-10.10.5.100
add address-pool=dhcp interface=bridge lease-time=1m name=defconf
/ppp profile
add local-address=l2tp_pool name=l2tp remote-address=l2tp_pool
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface l2tp-server server
set authentication=mschap2 default-profile=l2tp enabled=yes use-ipsec=yes
/interface wireguard peers
add allowed-address=10.11.12.13/32 comment=d-laptop interface=wg-snet persistent-keepalive=25s public-key=
“4i+kXXXXXXXXXYXOEI=”
add allowed-address=10.9.8.7/32 comment=d-laptop interface=wg-snet persistent-keepalive=25s public-key=
“BuKMXITRXXXXXXRAQ=”
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=10.11.12.1/24 interface=wg-snet network=10.11.12.0
add address=10.9.8.1/24 interface=wg-vpn network=10.9.8.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=accept chain=input comment=l2tp dst-port=1701,500,4500
in-interface-list=WAN protocol=udp
add action=accept chain=input comment=wg-snet dst-port=22522 in-interface-list=
WAN protocol=udp
add action=accept chain=input comment=wg-vpn dst-port=13531 in-interface-list=
WAN protocol=udp
add action=accept chain=input comment=“Access MT from d-laptop” dst-port=
22,23,80,8291 in-interface=wg-snet protocol=tcp src-address=
10.11.12.13
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=
invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed”
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment=“Block Internet for WG-SNet”
out-interface-list=WAN src-address=10.11.12.0/24
add action=drop chain=forward comment=“Block LAN for WG-VPN”
out-interface-list=LAN src-address=10.9.8.0/24
add action=reject chain=forward comment=“Isolating wg-snet peers” in-interface=wg-snet out-interface=wg-snet reject-with=
icmp-network-unreachable
add action=reject chain=forward comment=“Isolating wg-vpn peers” in-interface=wg-vpn out-interface=wg-vpn reject-with=
/ip firewall mangle
add action=mark-packet chain=prerouting connection-state=new dst-address=
111.111.111.111 in-interface=bridge new-packet-mark=nat-loopback
passthrough=yes
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=
out,none out-interface-list=WAN
add action=masquerade chain=srcnat comment=“NAT Loopback replace address”
add disabled=no distance=1 dst-address=192.168.111.0/24 gateway=l2tp-in1
pref-src=192.168.88.1 routing-table=main scope=30 suppress-hw-offload=no
target-scope=10
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=pppoe-out1 type=external
/ppp secret
add name=skynet profile=l2tp service=l2tp
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Athens
/system note
set show-at-login=no
/system package update
set channel=testing
/tool mac-server
/tool mac-server mac-winbox
MT2
MT2
jan/07/2024 15:36:47 by RouterOS 6.49.6
software id = BGGS-1Q5G
model = 951Ui-2nD
add admin-mac=64:XX:XX:XX:XX:D6 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=ISP
set [ find default-name=ether2 ] comment=LTE
/interface l2tp-client
add allow=mschap2 comment=snet connect-to=111.111.111.111 disabled=no name=l2tp-out1 use-ipsec=yes
user=snet
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors
frequency=auto installation=indoor mode=ap-bridge ssid=Office2 wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=
MikroTik
add name=dhcp ranges=192.168.111.10-192.168.111.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add list=LAN
add interface=ether2 list=WAN
add address=192.168.111.1/24 comment=defconf interface=bridge network=192.168.111.0
/ip dhcp-client
add add-default-route=no comment=“Primary WAN” disabled=no interface=ether1
add add-default-route=no comment=“Redundant WAN” disabled=no interface=ether2
add address=192.168.111.0/24 comment=defconf dns-server=1.1.1.1,1.0.0.1
gateway=192.168.111.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.111.1 comment=defconf name=router.lan
add action=accept chain=input comment=“defconf: accept established,related,untracked”
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept to local loopback (for CAPsMAN)” dst-address=
127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=
established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked”
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none
add action=masquerade chain=srcnat disabled=yes out-interface=*9
add comment=“primary gateway” distance=2 gateway=192.168.1.1
add comment=“secondary gateway” distance=3 gateway=192.168.222.1
add distance=1 dst-address=8.8.8.8/32 gateway=192.168.1.1
add distance=1 dst-address=192.168.88.0/24 gateway=l2tp-out1 pref-src=192.168.111.1
/ip service
set ssh disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Athens
set channel=long-term
/tool mac-server
WG SNET USER
[Interface]
PrivateKey = XXXXXXXX=
Address = 10.11.12.13/32[Peer]
PublicKey = XXXXXXX=
AllowedIPs = 10.11.12.0/24, 192.168.88.0/24, 192.168.111.0/24
Endpoint = 111.111.111.111:22522
PersistentKeepalive = 25
