Access List Issue
Hi
In a scenario with two access points with MAC Access List authentication.
When adding MAC address to Access List of both Access points, then disable it from one of them.
Sometimes CPE keeps trying to connect to it with reject, and message keeps repeating (Not in local ACL, by default reject),
Why it doesn’t try to connect the other AP as its MAC is already enabled in the other AP ?
Thank U
and sorry for my English
I think a client will always try to connect to the AP with highest signal, as long as both APs have same SSID/WPA.
To lock a client to one specific AP you should make spesific SSID’s for each AP.
No need for it. You can use connect list to make rules for the client. If it is mikrotik.
