Hi All
I wonder What the Access List means, from its name it looks like
Groups of address in lists.
But if we check it in MK manual (web proxy for example) we find it
Talks about one source address for rule and do not accept address range.
While in the firewall rules it accepts an address range as source address.
Then is there is some way to make a one rule in web-proxy for a range
Of IP address’s as source address like firewall.
Thanks for every one.
Eng. Amgad Steen
if you need range - enter something like ‘192.168.0.1-192.168.1.254’ in address field
Thanks Mr. Chupaka for your replay
I try with Web-proxy to but ‘172.30.4.30-172.30.4.80’ In Src. address
But when I apply I get “Error in src. address - network address expected!”
It only accept the format 0.0.0.0/0 this includes all the range.
thanks
Eng. Amgad
Yes You are right
I have MK v3 On VMware Machine I try address range on its web proxy
and it accept it.
But is there some way with ver 2.9
Thanks very much
Eng Amgad
Ok
Thanks Mr. Chupaka
I will Upgrade my MK ver to 3
Thanks very much
Eng. Amgad steen
