Hi, I have the following setup:
ISP cable – My Switch – My MikroTik router – My Lan (via wifi or via cable, etc)
My router is MikroTik: rb4011igs+5hacq2hnd-in
RouterOS v7.3.1
My issue is that: I would like to access My Switch management console (running on something like 192.168.1.3 via http) from My Lan. (This currently does not work).
I have seen some threads with similar issues like mine but I am quite new to configuring MikroTik and I couldn’t figure out what’s needed. My setup is pretty much stock without specific customizations for the ethernet.
What I’ve tried so far is:
/ip/address add address=192.168.1.4/24 comment="Switch Network" interface=ether1 network=192.168.1.0
This allowed me to ping my switch from MikroTik console. However I am still unable to reach it from My Lan.
Here are my /ip settings:
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
set allow-remote-requests=yes
/ip dns static
/ip settings
set max-neighbor-entries=8192
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
Would you please advise how can I resolve my issue. I am curious of various options (routing to the address, or mapping to some specific port on the mikrotik IP, or something else).
