Greetings!
I used search and found several similar articles, however, solutions from there did not help me.
So, I have an VDSL modem (Vigor 130), being set in bridge mode and Mikrotik connected to it.
The Internet is working fine, but I cannot access Vigor 130 web interface in my setup.
And now, I am afraid, that I screwed up setup and it is not optimal/secure.
Could you, please, help me with understanding? Many thanks!
Here is the configuration:
# aug/27/2018 02:52:58 by RouterOS 6.43
software id = XXX
model = RouterBOARD 952Ui-5ac2nD
serial number = XXX
/caps-man datapath
add client-to-client-forwarding=yes name=datapath1
add admin-mac=MAC auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=
ether2-master
set [ find default-name=ether3 ] advertise=
set [ find default-name=ether4 ] advertise=
set [ find default-name=ether5 ] advertise=
/interface pppoe-client
add add-default-route=yes default-route-distance=0 disabled=no interface=
ether1 name=NAME password=PASSWORD use-peer-dns=yes user=
USER
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=""
mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=
KEY wpa2-pre-shared-key=KEY
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
set discover-interface-list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=
192.168.88.0
add address=192.168.1.1 interface=ether1 network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
/ip firewall address-list
add address=8.8.8.8 list=GOOGLE_DNS
add address=8.8.4.4 list=GOOGLE_DNS
add action=accept chain=input comment="defconf: accept established,related"
add action=drop chain=input comment="defconf: drop all from WAN"
in-interface=ether1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=accept chain=forward comment="defconf: accept established,related"
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
connection-state=new in-interface=ether1
add action=drop chain=input src-address=138.122.34.191
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp
add action=drop chain=input connection-type="" dst-port=53 in-interface=
ether1 protocol=tcp src-port=""
add action=masquerade chain=srcnat comment="defconf: masquerade"
out-interface=telekom
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.0.0/24 port=12345
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.0.0/24
/ip upnp
set enabled=yes
/system clock
/system ntp client
set enabled=yes
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
