i have a question (i already succeded in doing this, but i forgot to save config and now i’m lost)
rb2011uas-2hnd
port1 is connected to modem who has ip 192.168.1.1, and i have pppoe interface on it
port 2 to 4 are in bridge mode, network 192.168.1.0/24, mikrotik has ip 192.168.1.2
internet and everything works no problem (nat masquerade), dhcp server is on lan bridge (192.168.1.32-192.168.1.64)
how do i get to access to modem page? i know that i can change the modem ip to different subnet and set up masquerade..
but i already managed to get to modem (added ip on port1 eg 192.168.200.200, and fiddled on ip firewall rules - but i dont remember what was it)
yeah, it isn’t working…i cannot ping the modem from mikrotik (interface: lan_bridge)
if i ping it from wan port (port1) works like a charm..
but i do not have access to wan port directly, because it has pppoe interface on it and so it is not in lan_brige
Put ehter1 into the bridge and put the pppoe client on the bridge too. Your modem is on the same broadcast domain (IP subnet) as your local lan, so therefor there can’t be a router in between and the need to be on the same Layer2 segment.
