access point configuration problem help???
hi everybody
i have configured an access point with rb433 (three card).
and sector anteena is 17dbi
what is anteena gain ?what is the adject number of anteena gain .i configured it 17 dbi.
and what frequency i would use in 802.11b mode . i configured it 2452
and what is adaptive noise immunity(by default is set to none ).i configured it to ap and client mode.
-what is preamble mode (which one is the best
long
short
both
-what is Ack time out
-what is noise floor threshold
-what is brust time
-hardware retries
-frame lifetime
Set different frequencies on each interface,
Live them in default mode except if you have any reason for making changes.
All the interfaces should be on “AP-Bridge” mode.
You need to bridge all the interfaces together with the ethernet port in use. I am sure you must have done that. just to be sure.
if you would like to setup AP directly between two interfaces then you have to bridge them (your internet source interface with wlan interface). Don’t forget to select “AP-Bridge” mode for wlan.
thanks
for reply
but i have configured it as access point (bridged).
so kindly tell me the additional configuration parameter.mentained above
with regard
suraj
