Access-Point Indoor or outdoor in bridge mode
HI!
somebody can tell me, a good device example Edimax, indoor, AP this device, i can change from AP to client-bridge,
i want a CPE low cost, the good CPE with internal antenna, is very good solution, example tranzeo, smartbridges Mikrotik ,etc, but in my country is to high the price, because have control about the dolars. 1 $ = 3000 bolivares, the normal or excelente economy is 1$ = 1 bolivar, you urdestand now.
now i can put little indoor AP change to mode to Client, and can work, of course, i will need the external antenna, cable RG58 or RG8, but work. more piece, and more troubleshooting, but work.
what is device you recommend, or you tested for this CPE low cost.
Thanks in advance
because this is a mikrotik specific forum, i have to say that the cheapest CPE is RB112 + R52 :slight_smile:
ok, but, how i can buy in Venezuela, or in EE.UU because is very hard buy Mikrotik Radios for South America.
Thanks in Advance
http://www.mikrotik.com/howtobuy.html
