I have rb951ui-2hnd. How to be positioned for the best signal level?
Waiting for your suggestions about it.
In the middle of nothing.
does it matter standing horizontal or vertical at a table?
Reflections and obstacles will have much more influence than box orientation itself.
do a site survey
Make sure there isn’t metallic objects, thin walls and other same frequency sources around. Every client should have clear line of sight with AP, in real environment it’s almost impossible however it should be objective. Don’t place your AP too high.
This board is made to stand horizontal.
