Access Point setup
Hi all,
I am trying to set up an access point using an X86 system running ROS 3.3 and two mini-pci cards. The cards are connected via an RB 14 mini pci to PCI adapter. Both cards a recognized by the system. The problem is that I don’t see a “R”, on the line with both cards, meaning that the are not running. How do I solve this? They are both enabled. TIA
You will only see an “R” If the interface is connected and receiving.
if that first field is blank, it does mean the card is online, and if in ap mode it will be sending beacons, in station / client mode it will be actively seeking out
an access point to connect to.
Ok thanks for the info. I guess they are working because also if I do a scan I can see other wireless connections..
I have another X86 box that I’d like to connect this access point to, and have that router be the DHCP server/ main connection to the internet.
On the access point i created a bridge that has one ethernet card and 2 WLAN cards. The ethernet card will be used to connect the main router. I added an IP address to the bridge. Is this the way to do it?
That is “a” way to do it.
if you are just doing simple bridging, that should be just fine.
I have read the wiki and searched the forum, but have not found anything else. This is eventually what I’d like to do: Have all CPEs being authenticated by usermanager of the main router, so that I can also controll bandwidth. What is the best way to connect the access point router to the Main router? Pls advise.
This may sound silly, but how can I verify that the Access Point is working? I am not seeing it when doing a survey a couple block away. How can I verify what power is being put out by the radio? TIA
