We have installed a mikrotik as a base station.
My question is which equipment should be used at customer end. Suggest me the equipment which should have good performance and also affordable price.
Thanks & Regards
Shaggy
Thanks & Regards
Shaggy
for 2.4 or 5.8 GHz?
My Suggestion:
MikroTik RB 411..
For 2.4GHz
Ashish thts fine but i think it will cost more. btw what is the best price for tht.
The Best Answer.
http://www.mikrotik.com/howtobuy.html
ASIA/INDIA Section.
And Again you have to spend Money if you want a BEST Soultion.
