i am using RB532 series router. i am planning to implement wifi access points across the office campus. is there a way to use the same authentication password across the access points without the need to authenticate while connecting to other access points if already authenticated with one
i do not want to connect to a hotspot as this wifi i want to use only in places where wired network is not available. i just wanted all the access points to share the same profile, something on the lines of what a repeater does.
