Access port config
Hello.
Help please.
Provider gives 2 ip on one wire
I have tp -link with 2 wan ports. I put in front of tp-link, mikrotik. It is necessary to divide IP by vlan.
I attach the picture. I hope it is clear.
Teams that I do:
set ether2 master-port=ether1
set ether3 master-port=ether1
set ether1 vlan-mode=secure vlan-header=add-if-missing
set ether2 vlan-mode=secure vlan-header=always-strip default-vlan-id=453
set ether3 vlan-mode=secure vlan-header=always-strip default-vlan-id=1766
add ports=ether1,ether2 switch=switch1 vlan-id=453 independent-learning=yes
add ports=ether1,ether3 switch=switch1 vlan-id=1766 independent-learning=yes
What am I doing wrong ?
