Access problem to the router MikroTik RB2011UAS-2HnD-IN
Sorry for my bad English)
Hello.
Please help with configuring access to the router without using the reset.
My Hardware: MikroTik RB2011UAS-2HnD-IN, beeline ISP L2tp, Win7.
I set up a router with Winbox connection Beeline internet works, and began to configure wi-fi, changed SSID, set the frequency, but there is no connection with my smartphone.
I read on the internet, what ineed to enter through 192.168.88.1/cfg and security settings to tick the box on the Firewall, NAT, and something else, so did he, in relation to the port where the cable comes from the Beeline (ISP).
Result/Problem: Internet works, wi-fi is not working. I can not log on the router.
Error messages:
  • When trying through Winbox (MAC) - Could not connect to _ (mac adress) _ (port 20561) - timed out!
  • When trying through Winbox (IP) - long connects to port 8291, and then writes the Port 0, then the message: Could not connect to _ (IP adress: 80) _ - no response!
    Kindly explain the method call in the router, or to cancel the entry rules and NAT Firewall, without using the Reset.
    thanks
Please make sure you have connected cable to Ethernet2 port, try different Windows computer.
