Access Public IP from Internal, private network [solved]
I have a php server that must serve its pages with the Public IP.
I have people locally from 192.168.6.x address that need to be able to type in
http://PUBLIC_IP/
and have teh router redirect that to the php server at 192.168.6.198.
seems to me this should be accomplished by a DST-NAT rule dst=public IP
can NOT get it it work.
tks
the dst-nat rule was working.
problem was:
i had to turn masquerading on, on eth1 the 192.168.6.0/24 port.
tks
you cannot dst-nat to the same subnet. packets should go through the router in both directions
i agree, but when im a client such as 192.168.6.x and i try to access the public ip of the same router, with a specific port, the router has to be told where to redirect that port to.
that was the issue
tks
you cannot just redirect 192.168.6.x to 192.168.6.198. you should move 192.168.6.198 to another interface, or use split DNS, so that external users resolve you server’s name to public IP and internal users resolve it to private IP
hi,
i was talking about redirecting the PUblic IP to a port. thus when internal client 192.168.6.x accesses http://public_IP it goes to 192.168.6.198 port 8300.
or they could: http://my_static_set_dns.com
the site works fine for people on the internet.
to clear up the layout:
Public IP is on ether2 \ router is 192.168.6.1 on ether1. \ all 192.168.6.x clients are on a switch plugged into ether1
all 192.168.6.x are nat Masqueraded to use ether2’s public ip
(and to be clear, the issue is fixed we are just discussing the idea)
thanks
to be clear, the issue is not solved, it’s worked-around
now your server receives requests from the address of your router, i.e. you cannot determine, who exactly asks your web-server for some page
let’s consider in more detail what happens in both cases.
case 1: someone from an external network sends a packet to your_public_ip:80. router receives this packet, processes NAT rules, changes dst-address of packet to 192.168.6.198:8300 and sends it to the web-server. the web-server sees a packet from external_user_ip to 192.168.6.198:8300, processes it and sends the response to external_user_ip. router receives a packet from 192.168.6.198:8300 to external_user_ip, changes src-address to your_public_ip:80 and sends a packet to external user. all is good.
now,
case 2: internal user. for example, 192.168.6.2. he sends a packet to your_public_ip:80. router receives this packet, processes NAT rules, changes dst-address of packet to 192.168.6.198:8300 and sends it to the web-server. the web-server sees a packet from 192.168.6.2 to 192.168.6.198:8300, processes it and sends the response to 192.168.6.2. but this response do not pass the router, so 192.168.6.2 receives a packet from 192.168.6.198. but he don’t want a packet from 192.168.6.198 - he asks for connection to your_public_ip, so he simply drops the packet. oops…
So Chupaka, how would you set-up a split DNS for this to work? I’m interested in the result even if the OP isn’t.
use Bind. you cannot do it in ROS
thanks!
Sure you can use MT to solve a problem. Simply set static DNS entry in MT DNS to override public IP with local IP for the same mnemonic address.
