High every one
i have this ;
MT RB433 (station wds) connected to TP link router TL-WR740N( PPPoe to access internet) coonected to PC
via wireless .
How to access RB433 via win box?
again
RB433-TP link-PC WLAN how to access RB433 via win box (in PC)
thanks
reset to default settings wds works transparant you can’t see the Mikrotik router
If im gonna reset then im gonna lose my internet service
Yes indeed, config the routherboard without transparant wds if you can.
Thanks a lot for your responses but i think i was not clear enough. the router board is not transparent at all and every time i need to login into router board i had to use wire connection directly to my Ethernet port in my laptop and it is boring .what i need is to log in to rb433 while i am connected to my TP link wireless router . is that possible?
If this is in the same IP-range Yes.
i will try and let you know
Thanks alot
