this is not directly RouterOS related, but maybe someone already implemented something like this.
What’s the plan ?
I’d like to give some people Read Access to the Web Management UI of some RouterOS v6.0 devices.
Due to some networking restrictions, i cannot give them direct access to the Webinterface, so i thought i use an existing Apache Webserver, and configure it as Reverse Proxy, which forwards the traffic then to the RouterOS boxes.
[Client] <---> [Apache Reverse Proxy] <---> [Multiple RouterOS Webinterface(s)]
What did i configure ?
On the Apache, i ensured the proxy modules were enabled and as a first and simple test, i added the follwing configuration to the referring httpd configuration (SSL will be done when this one works):
# RouterOS - Proxied WebUI Access Test
ProxyPass /fw-int1/ http://10.10.10.1/
<Location /fw-int1/>
ProxyPassReverse /
</Location>
So when i access now my Webserver on http://172.16.4.35/fw-int1/ i got the RouterOS Web Login Mask presented from my Apache.
What’s the (my) Problem ?
As soon as i try to login, the webserver wants to access http://172.16.4.35/webfig/ [instead of something like http://172.16.4.35/fw-int1/webfig/ ] which of course does not exist. So it seems the RouterOS Webinterface doe snot just use relative paths, but uses absolute web path instead.
I guess this could be fixed with some proxy rewrite rules ?
But before i have a detailed look at this, i wonder if anyone already implemented something like this ?
As i don’t see a reason to invent the wheel again ![]()
Regards
Lewis
