Access to a MT winbox behind another MT
I have put a MT,called mt_slave, behind another MT, called mt_master.
I have a ADSL router to exit to Internet. I redirecct 8081 and 3987 ports of the DSL router to access mt_master.
My question is how can I access to the winbox of the MT mt_slave?Because I can change 8081 hotspot port, but I can not do the same with 3987 port since it is specific of winbox.
I know that winbox use these ports:
  • 8081 hotspot port
  • 8291 ? port
  • 3987 winbox port
How can access to mt_slave ?
I would suggest creating a management VPN connection to your master - from there you could access everything “behind” it. Use PPTP or IPsec - I believe someone in the forum once did create a step-by-step-description for that case…
awacenter, if yoou finf a way, please publish it thanx
