Access to all Routerboard from a single point in the network
I’d like to access from one network to all devices on my network MT. for example, plug in the router 1 (I’m in the network 192.168.88.0/24) and derives from them access to all the routers and APs. How can I do that. It’s about gaining access to the winbox and Dude.
Hello
If you are in a routed network, you can use static routes or maybe vpn (pptp for example).
I would prefer pptp, i.e. every device starts a pptp connection to the main router, so you can access the devices through their new client vpn ip.
If all your devices are in bridge/switch then you should have access directly. If you want to join two networks over the Internet you need to make some tunnel and route the traffic through it. Each network should have different subnet of course.
Check out RoMON - it’s great for this. You may need EoIP / IPSEC tunnels between the devices though.
http://wiki.mikrotik.com/wiki/Manual:RoMON
Thank you for your interest and support.
I used the first idea, but the rest of it I learned a lot. :smiley:
i am using nat rules in main router to connect from outside to rbsxt in the same network.
romon feature is really cool, but for me does not work. i always get the message “disconnected” when i connect with romon to main router and after i try to connect to discovered devices. i have just enable romon tick in tools romon. nothing else special.
can u give an example of how is the setup with vpn. u mean that i setup vpn server (pptp) to router and to rbsxt ap i setup vpn client to connect to main router, right? after what? how i connect to ap from outside?
