Access to local network from IKEv2 tunnel
Hi.
I want to config IKEv2 tunnel for connecting from internet into LAN. Now tunnel connects and internet works, but I cannot access devices on LAN through tunnel (without masquerade).
On PPTP it was sufficient to set proxy-arp on bridge, but it don’t work here.
I guess that is because IPsec remote peer local address is set to 192.168.1.2 (router address on WAN, DMZ from globally reachable address), but I want to access LAN 192.168.0/24 (with 192.168.0.1 router address)
policies:
1 T   group=vpn-policies src-address=0.0.0.0/0 dst-address=192.168.0.0/24
       protocol=all proposal=vpn-proposal template=yes
proposals:
1    name="vpn-proposal" auth-algorithms=sha256,sha1
      enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=8h
      pfs-group=none
peers:
 0   R address=0.0.0.0/0 passive=yes profile=default auth-method=pre-shared-key
       secret="xxx"
       generate-policy=port-strict policy-template-group=vpn-policies
       exchange-mode=ike2 mode-config=vpn-conf send-initial-contact=yes
mode configs:
 1  R name="vpn-conf" system-dns=yes address-pool=vpn-pool
      address-prefix-length=32
pools:
 1 vpn-pool                                       192.168.0.50-192.168.0.99
addresses:
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.0.1/24     192.168.0.0     bridge-local
 1   192.168.1.2/24     192.168.1.0     ether1-gateway
routes:
 0 A S  0.0.0.0/0                          192.168.1.1               1
 1 ADC  192.168.0.0/24     192.168.0.1     bridge-local              0
 2 ADC  192.168.1.0/24     192.168.1.2     ether1-gateway            0
