Access USB Dongle's Web Interface
Hi
I have an LTE/3G dongle connected via USB to my RB750.
My network range is 192.168.0.*
The dongle is on 192.168.8.1
How can I access the web interface of the dongle from a computer on my network?
nobody?
actually, you should have it. check your firewall rules. i think you have smth like “HiLink” modem. It has it’s own DHCP that gives ip gw and dns to LTE interface in RB. Check if there is a route to 192.168.8.* subnet
Hi
Did you solve your problem? I can’t either access web interfece on 192.168.8.1. Pinging it from mikrotik works all right. Modem itself works very well as well.
I just can’t make it working with web interface. Should I have special firewall rule for it. Routes to 192.168.8.1 is made automatically on connect.
anything new about this workaround?
