Now, I would like to have access to the configurations using webfig so using winbox I went to “IP → addresses” and added an IP “192.168.1.149/24” Network “192.168.1.0” to the interface “bridge”. Unfortunately this doesn’t work. What am I’m doing wrong, and how can I achieve the desired result?
Is the 192.168.1.149/24 in the same range that the DHCP server will assign to another client connected in that segment - if not - then you need to add secondary address on your machine in the 192.168.1.0/24 network as well.
A more easy way would be to set that mikrotik with dhcp-client in the bridge and optionally add a static mapping on whatever dhcp server you are using. Also make sure that the /ip/services are allowed from the subnet you are getting from the dhcp.
