Access Winbox with starting configuration
I have a hAP with default configuration (switch eth2-3-4-5-wifi, dhcp server, dhcp client on eth1)
I would like to reach Winbox since eth1 ( internet )
Default configuration of firewall :
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept established,related” connection-state=established,related
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related” connection-state=established,related
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=ether1
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=ether1
With default configuration, it is not possible to access the router with Winbox from internet (eth1)
So i add this rules :
add action=accept chain=input comment=“Winbox from Internet” dst-port=8921 protocol=tcp
But it doesn’t works..
Can you help me ?
Remove this rule
interface=ether1
Yes i know this will work if i remove this rule
But it is more secure no ?
Is it possible to drop all exept 8921 ?
And if i put my rule before the drop all, why doesn’t works ??
Just a guess:
a. put your input before any drop rule
add action=accept chain=input comment="Winbox from Internet" dst-port=8921 protocol=tcp in-interface=ether1
b. disable rule
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1
Does it work now ?
kind regards,
No,
It works only when i disable : add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=ether1
Port number is 8291..
Sharp eyes… i did not notice it :slight_smile:
add action=accept chain=input comment="Winbox from Internet" dst-port=8291 protocol=tcp in-interface=ether1
kind regards,
OMFG !
2 days !!
RTFM slowly.. :frowning:
Sorry and thanks
No problem. Anytime :slight_smile:
kind regards,
