accessing Ap's from the internet
please i need help in accessing my Ap’s from the internet via winbox i have a setup like
1-internet gateway with 14 public ip available
2-Base RouterOS connected through ethernet LAN to the GateWay
3-the base has 2 wireless adapters one set as access point the other as access poing over 5.8 to accomodate a distance link
4-the Distance RouterOS has 3 wireless adapters one 2.4 setup as AP to the clients and 2 as 5.8 links
5- one of the 5.8 is connected back to the Base RouterOS via its 5.8 adapter
6- the second 5.8 on the distance is connected to third RouterOS with 2 wireless adapters
7-the network address for each router is different from the others
i can see only one routerOS from the internet
please i need help
thank you
Just setup VPN access
jwcn -
You forgot to tell him to change the ‘local’ LAN side NIC to proxy-arp mode to access everything on the local side from a VPN connection… :slight_smile:
