I’ve searched and found this thread on how to access my DSL modem but it’s not working for me. http://forum.mikrotik.com/t/how-to-access-external-router-via-wan-port-on-rb750/56317/1
As a new MikroTik user I copied and pasted a firewall from their wiki to get started and I’ll paste it here in case what’s blocking my access can be found there:
ip firewall address-list
add address=192.168.2.0/24 list=support
add address=0.0.0.0/8 comment=“Self-Identification [RFC 3330]” list=bogons
add address=127.0.0.0/16 comment=“Loopback [RFC 3330]” list=bogons
add address=169.254.0.0/16 comment=“Link Local [RFC 3330]” list=bogons
add address=192.0.2.0/24 comment=“Reserved - IANA - TestNet1” list=bogons
add address=192.88.99.0/24 comment=“6to4 Relay Anycast [RFC 3068]” list=bogons
add address=198.18.0.0/15 comment=“NIDB Testing” list=bogons
add address=198.51.100.0/24 comment=“Reserved - IANA - TestNet2” list=bogons
add address=203.0.113.0/24 comment=“Reserved - IANA - TestNet3” list=bogons
add action=add-src-to-address-list address-list=Syn_Flooder address-list-timeout=30m chain=input comment=“Add Syn Flood IP to the list” connection-limit=
30,32 protocol=tcp tcp-flags=syn
add action=drop chain=input comment=“Drop to syn flood list” src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner address-list-timeout=1w chain=input comment=“Port Scanner Detect” protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment=“Drop to port scan list” src-address-list=Port_Scanner
add action=jump chain=input comment=“Jump for icmp input flow” jump-target=ICMP protocol=icmp
“Block all access to the winbox - except to support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT ADDRESS LIST” disabled=yes
dst-port=8291 protocol=tcp src-address-list=!support
add action=jump chain=forward comment=“Jump for icmp forward flow” jump-target=ICMP protocol=icmp
add action=drop chain=forward comment=“Drop to bogon list” dst-address-list=bogons
add action=add-src-to-address-list address-list=spammers address-list-timeout=3h chain=forward comment=“Add Spammers to the list for 3 hours”
connection-limit=30,32 dst-port=25,587 limit=30/1m,0 protocol=tcp
add action=drop chain=forward comment=“Avoid spammers action” dst-port=25,587 protocol=tcp src-address-list=spammers
add chain=input comment=“Accept DNS - UDP” port=53 protocol=udp
add chain=input comment=“Accept DNS - TCP” port=53 protocol=tcp
add chain=input comment=“Full access to SUPPORT address list” src-address-list=support
add action=drop chain=input comment=“Drop anything else! # DO NOT ENABLE THIS RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED” disabled=yes
add chain=ICMP comment=“Echo request - Avoiding Ping Flood” icmp-options=8:0 limit=1,5 protocol=icmp
add chain=ICMP comment=“Echo reply” icmp-options=0:0 protocol=icmp
add chain=ICMP comment=“Time Exceeded” icmp-options=11:0 protocol=icmp
add chain=ICMP comment=“Destination unreachable” icmp-options=3:0-1 protocol=icmp
add chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment=“Drop to the other ICMPs” protocol=icmp
add action=jump chain=output comment=“Jump for icmp output” jump-target=ICMP protocol=icmp
add action=drop chain=input src-address=218.2.0.123
add action=drop chain=input src-address=144.0.0.61
add action=masquerade chain=srcnat comment=“Masquerade PPPOE” out-interface=pppoe-out1
add action=src-nat chain=srcnat comment=“NAT access to adsl modem” dst-address=192.168.1.1 out-interface=ether1-master-local to-addresses=192.168.1.2
MikroTik IP is 192.168.2.1
Bridged DSL modem is 192.168.1.1
Can someone explain what the code listed in the above post is doing? Any idea why it’s not working for me? I can plug directly into the modem and assign my laptop an 192.168.1.xxx IP and get into the DSL modem but it would be nice to access it from the 192.168.2.0 network.
