Accessing device from another subnet
Hello.
I’ve been struggling for the past few days to set up my home network with my Mikrotik hAP ac3.
What I want to accomplish is the following:
  • wireless interfaces (wlan1, wlan2) are separated and they don’t have access to ether3/4/5
  • ether3/4/5 are separated and they don’t have access to wi/fi
  • ether2 should be accessible from both the wireless network and ether3/4/5 network (I want to host my DNS server with pi-hole here).
All of the above should have access to the internet.
So far I managed to create 2 bridges - 1 for wifi, 1 for ether3/4/5, added DHCP servers, IP pools, network addresses - both have internet access and work. I was planning to add the third bridge for the ether2 (pi-hole), but for testing purposes, I assigned ether 2 to the wifi bridge and added routes in IP/Routes (see image). In the IP->ARP I’m seeing that the IP assignment is successful, but I’m not able to reach the pi-hole (wi-fi bridge) from ether3 (ether3/4/5 bridge). What am I doing wrong? Is there a better way to do what I’m trying to do?
Here’s my config:
add admin-mac=08:55:31:FD:FE:EF auto-mac=no comment=defconf name=bridge
add name=bridge-wifi
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=Venera wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    installation=indoor mode=ap-bridge ssid=Venera wireless-protocol=802.11
/interface vlan
add interface=wlan1 name=vlan-private vlan-id=1
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=08874541551 \
    wpa2-pre-shared-key=08874541551
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=wifi-pool next-pool=dhcp ranges=192.168.89.100-192.168.89.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=wifi-pool disabled=no interface=bridge-wifi name=wifi-dhcp
add bridge=bridge-wifi comment=defconf interface=ether2
add bridge=bridge-wifi comment=defconf interface=wlan1
add bridge=bridge-wifi comment=defconf interface=wlan2
add interface=bridge-wifi list=LAN
    192.168.88.0
add address=192.168.89.1/24 interface=bridge-wifi network=192.168.89.0
/ip arp
add address=192.168.88.253 interface=bridge mac-address=A0:BD:1D:E7:B0:A6
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
add address=192.168.89.0/24 gateway=192.168.89.1 netmask=2
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add action=accept chain=forward in-interface=bridge-wifi out-interface=bridge
add action=accept chain=forward in-interface=bridge out-interface=bridge-wifi
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add distance=1 dst-address=192.168.88.0/24 gateway=bridge-wifi pref-src=\
    192.168.89.1
add distance=1 dst-address=192.168.89.0/24 gateway=bridge pref-src=\
    192.168.89.1
/system clock
set time-zone-name=Europe/Sofia
/tool mac-server
/tool mac-server mac-winbox
