I recently changed ISP. I used to have a modem, now I am using PPPoE. I had to add the PPPoE interface, and change Filter and NAT rules to use the new PPPoE interface instead of the WAN ethernet-1 gateway I was using before (I hope that is correct). Internet and everything seems to be working fine. GRC’s Shields Up says my firewall is safe.
I have a NAS and a couple other services on my network. I also have DDNS setup and working. I have setup the appropriate port forwarding and everything seems to be working fine from outside my network. However, if I use the DDNS domain xxxxxxx.com:XXXX from within my network, it doesn’t work.
Still doesn’t seem to work. How do I chose the out-interface? What else could I be missing? What position in the NAT should this masq be in? Beginning, end?
What IP do you use ?
The problem is that this rule have to follow DDNS address. How ?
Instead of dst-address use dst-address-list which list should have your ddns address added as follow:
Yes, I had the first rule added, but without a dst-address and with a random port for my NAS admin panel, not port 80. Access from the outside worked. I added my temp dynamic IP address for testing, and it still works accessing from outside.
I do have DDNS but for now I’m trying to get to work assuming I have fixed IP.
My masquerade/hairpin NAT still doesn’t seem to work. I also tried with scr-address the IP address of my current computer, instead of 192.168.88.0/24. Could it be the out-interface?
… does it perhaps have in-interface=? That would be problem, because when connecting from LAN, in-interface is - no surprise - LAN. So you need either dst-address= or dst-address-type=local (= any address owned by router). For the latter, if you want to use some port that you also need to access on router (e.g. 80 for WebFig), add dst-address=!<router’s internal address>.
Sob, you are correct, my dstnat had my new PPPoE as in the in-interface. Good catch! It looks like BartoszP also had the solution, but I hadn’t noticed that he didn’t have an in interface in his solution. As I have DDNS, I had to create a dst address list with my DDNS domain. It seems to be working now.
Not quite sure I understand why I didn’t need a masquerade when I had an external modem on my WAN, but need one with a PPPoE internet.
