Accessing MikroTik RouterOS on another subnet
I spent some time researching before I asked this question.
I have an old computer, with two interface cards, that I installed RouterOS on.
ether1 is currently set as a DHCP client and receives and IP address from my current DD-WRT router. That network is 192.168.10.0
ether2 is current set as a DHCP server and has the network of 192.168.200.0.
I didn’t want users behind ether2 to see devices on ether1, so I set a simple firewall rule to block any packets to the 192.168.10.0 network. This is working fine. Anything behind ether2 can get online, using the DD-WRT as the gateway, but can’t see any devices on it.
I have VPN set up on the DD-WRT box. I can VPN into it fine, and see devices on the .10 network. Of course, I can’t see anything on the 192.168.200.0 network, but I would like to be able to. For testing, I set up a VPN server on RouterOS, and assumed I could VPN into my .10 network, then VPN to my .200 network. This worked, and I could ping the RouterOS at 192.168.200.1, however, I could not ping any other device on the RouterOS .200 network.
I don’t understand static routes yet, and honestly not sure how to do this.
I would simply like to VPN and see devices on the .200 network. What’s the best way to do this?
Thanks for any advice and help.
You need to provide more information for people to be of assistance. Namely your firewall rules, in particular what rule(s) you used to block traffic between the routed interfaces. Also we would need to see your setup for the VPN tunnel to the MikroTik, specifically what IP address is assigned to your tunnel.
Looks like my firewall rule was the culprit.
I have it dropping any packets on the .10 network. When I disabled that firewall rule, everything worked fine.
Basically the router behind a router isn’t a good setup. This was temporary. Eventually I will have everything running ONLY through the Mikrotik router.
