Hi everyone!
I’m trying to execute some commands in my Mikrotik router via Python scripts. With Paramiko, I’m currently able to access the router and execute the commands. However, some of them are a little bit ‘risky’ and I would like to run them using Safe Mode. According to the ASCII table, CTRL+X command can be introduced by sending \x18 to the router. However, if I do that, I see not response at all.
Said that, I would like to know if someone here has used a similar solution to access the router in Safe Mode. If so, I would aprecciate some help with that.
Thanks.
