Hi there,
I have a RB5009 with a set of VLANs. I want to use an access point cAP XL ac on a trunk port. Each VLAN should be assigned to a separate WLAN SSID. I want to use the DHCP server of the RB5009 for the WLANs. The AP is connected to ether3 of the RB5009 using ether1 of the AP. When I use a DHCP client on the access point, the AP is able to get a IP address from the RB5009. But the WLAN clients connecting to the AP do not get a valid IP. Any idea?
Configuration of RB5009:
#RB5009
add comment="Main LAN bridge (VLAN-aware)" name=br-lan vlan-filtering=yes
set [ find default-name=ether1 ] comment="WAN (internet) - keep closed to remote access"
/interface vlan
add comment="SVI for LAN (trusted)" interface=br-lan name=vlan20 vlan-id=20
add comment="SVI for Guest" interface=br-lan name=vlan30 vlan-id=30
add comment="SVI for IoT with internet" interface=br-lan name=vlan40 vlan-id=40
add comment="SVI for IoT no-internet" interface=br-lan name=vlan41 vlan-id=41
add comment="SVI for Admin" interface=br-lan name=vlan100 vlan-id=100
add name=TrustedPorts
add name=pool-vlan20 ranges=192.168.20.10-192.168.20.250
add name=pool-vlan30 ranges=192.168.30.10-192.168.30.250
add name=pool-vlan40 ranges=192.168.40.10-192.168.40.200
add name=pool-vlan41 ranges=192.168.41.10-192.168.41.200
add name=pool-vlan100 ranges=192.168.100.10-192.168.100.50
add bridge=br-lan comment="LAN - untagged VLAN20" interface=ether2 pvid=20
add bridge=br-lan comment="AP1 trunk - native VLAN20, tagged VLAN30" interface=ether3 pvid=20
add bridge=br-lan comment="AP2 trunk - native VLAN20, tagged VLAN30" interface=ether4 pvid=20
add bridge=br-lan comment="IoT (internet) - VLAN40" interface=ether5 pvid=40
add bridge=br-lan comment="IoT (internet) - VLAN40" interface=ether6 pvid=40
add bridge=br-lan comment="IoT (no-internet) - VLAN41" interface=ether7 pvid=41
add bridge=br-lan comment="Admin access - VLAN100" interface=ether8 pvid=100
/interface bridge vlan
add bridge=br-lan comment="Trusted LAN" tagged=br-lan,ether3,ether4 untagged=ether2 vlan-ids=20
add bridge=br-lan comment=Guest tagged=br-lan,ether3,ether4 vlan-ids=30
add bridge=br-lan comment=IOT-Internet tagged=br-lan untagged=ether5,ether6 vlan-ids=40
add bridge=br-lan comment=IOT-NoInternet tagged=br-lan untagged=ether7 vlan-ids=41
add bridge=br-lan comment=Administration tagged=br-lan untagged=ether8 vlan-ids=100
add address=192.168.20.1/24 comment="LAN VLAN20" interface=vlan20 network=192.168.20.0
add address=192.168.30.1/24 comment="Guest VLAN30" interface=vlan30 network=192.168.30.0
add address=192.168.40.1/24 comment="IoT VLAN40" interface=vlan40 network=192.168.40.0
add address=192.168.41.1/24 comment="IoT VLAN41 (no internet)" interface=vlan41 network=192.168.41.0
add address=192.168.100.1/24 comment="Admin VLAN100" interface=vlan100 network=192.168.100.0
/ip dhcp-client
add comment="DHCP client on WAN" interface=ether1
add address-pool=pool-vlan20 interface=vlan20 lease-time=12h name=dhcp-vlan20
add address-pool=pool-vlan30 interface=vlan30 lease-time=6h name=dhcp-vlan30
add address-pool=pool-vlan40 interface=vlan40 lease-time=8h name=dhcp-vlan40
add address-pool=pool-vlan41 interface=vlan41 lease-time=8h name=dhcp-vlan41
add address-pool=pool-vlan100 interface=vlan100 lease-time=12h name=dhcp-vlan100
add address=192.168.20.0/24 dns-server=192.168.20.1,1.1.1.1,9.9.9.9 gateway=192.168.20.1 ntp-server=192.168.20.1 wins-server=192.168.20.1
add address=192.168.30.0/24 dns-server=192.168.30.1,1.1.1.1,9.9.9.9 gateway=192.168.30.1 ntp-server=192.168.30.1 wins-server=192.168.30.1
add address=192.168.40.0/24 dns-server=192.168.40.1,1.1.1.1,9.9.9.9 gateway=192.168.40.1 ntp-server=192.168.40.1 wins-server=192.168.40.1
add address=192.168.41.0/24 dns-server=192.168.41.1,1.1.1.1,9.9.9.9 gateway=192.168.41.1 ntp-server=192.168.41.1 wins-server=192.168.41.1
add address=192.168.100.0/24 dns-server=192.168.100.1,1.1.1.1,9.9.9.9 gateway=192.168.100.1 ntp-server=192.168.100.1 wins-server=192.168.100.1
set allow-remote-requests=yes servers=1.1.1.1,9.9.9.9
add action=accept chain=input comment="Allow established to router" connection-state=established,related
add action=accept chain=forward comment="Allow established in forward" connection-state=established,related
add action=accept chain=input comment="Allow ping from VLAN20" protocol=icmp src-address=192.168.20.0/24
add action=accept chain=input comment="Allow ping from VLAN30" protocol=icmp src-address=192.168.30.0/24
add action=accept chain=input comment="Allow ping from VLAN40" protocol=icmp src-address=192.168.40.0/24
add action=accept chain=input comment="Allow ping from VLAN41" protocol=icmp src-address=192.168.41.0/24
add action=accept chain=input comment="Allow ping from Admin VLAN100" protocol=icmp src-address=192.168.100.0/24
add action=accept chain=input comment="Allow WinBox from LAN" dst-port=8291 protocol=tcp src-address=192.168.20.0/24
add action=accept chain=input comment="Allow WinBox from Admin port" dst-port=8291 protocol=tcp src-address=192.168.100.0/24
add action=accept chain=input comment="Allow SSH from Admin" dst-port=22 protocol=tcp src-address=192.168.100.0/24
add action=drop chain=input comment="Drop all other input from WAN" in-interface=ether1
add action=accept chain=forward comment="Allow LAN->IoT(internet)" dst-address=192.168.40.0/24 src-address=192.168.20.0/24
add action=accept chain=forward comment="Allow LAN->IoT(no-internet)" dst-address=192.168.41.0/24 src-address=192.168.20.0/24
add action=accept chain=forward comment="Allow LAN ping Guest" dst-address=192.168.30.0/24 protocol=icmp src-address=192.168.20.0/24
add action=accept chain=forward comment="Allow LAN->WAN" out-interface=ether1 src-address=192.168.20.0/24
add action=accept chain=forward comment="Allow Guest->WAN" out-interface=ether1 src-address=192.168.30.0/24
add action=accept chain=forward comment="Allow IoT(internet)->WAN" out-interface=ether1 src-address=192.168.40.0/24
add action=accept chain=forward comment="Allow Admin->WAN" out-interface=ether1 src-address=192.168.100.0/24
add action=drop chain=forward comment="Block IoT(no-internet)->WAN" out-interface=ether1 src-address=192.168.41.0/24
add action=drop chain=forward comment="Drop other inter-VLAN forward traffic (default deny)"
add action=drop chain=input comment="Drop invalid input connections" connection-state=invalid
add action=masquerade chain=srcnat comment="Masquerade VLAN20 (LAN)" out-interface=ether1 src-address=192.168.20.0/24
add action=masquerade chain=srcnat comment="Masquerade VLAN30 (Guest)" out-interface=ether1 src-address=192.168.30.0/24
add action=masquerade chain=srcnat comment="Masquerade VLAN40 (IoT internet)" out-interface=ether1 src-address=192.168.40.0/24
add action=masquerade chain=srcnat comment="Masquerade VLAN100 (Admin)" out-interface=ether1 src-address=192.168.100.0/24
/ip service
set ftp disabled=yes
set telnet disabled=yes
/ipv6 address
add address=fd00:20::1 comment="ULA LAN fallback" interface=vlan20
add address=fd00:30::1 comment="ULA Guest fallback" interface=vlan30
add address=fd00:40::1 comment="ULA IoT internet fallback" interface=vlan40
add address=fd00:41::1 comment="ULA IoT no-internet fallback" interface=vlan41
add address=fd00:100::1 comment="ULA Admin fallback" interface=vlan100
/ipv6 dhcp-client
add add-default-route=yes comment="DHCPv6 client on WAN (requests PD)" interface=ether1 pool-name=delegated-prefix request=prefix
/ipv6 firewall filter
add action=accept chain=input comment="Established IPv6" connection-state=established,related
add action=accept chain=forward comment="Established IPv6 forward" connection-state=established,related
add action=accept chain=input comment="Allow ICMPv6 (ND / ping) to router from anywhere internal" protocol=icmpv6
add action=drop chain=input comment="Drop IPv6 input from WAN" in-interface=ether1
/system clock
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes multicast=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
/system package update
set channel=long-term
/tool graphing interface
add interface=ether1
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
Configuration of the AP:
#cAP XL ac
add comment="Bridge for VLAN20+30 trunk" name=br-vlan vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX comment="2.4 GHz radio" country=germany disabled=no distance=indoors frequency=auto hide-ssid=yes installation=indoor mode=ap-bridge ssid=myssid-base-Mgm
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX comment="5 GHz radio" country=germany disabled=no distance=indoors frequency=auto hide-ssid=yes installation=indoor mode=ap-bridge ssid=myssid-base-Mgm
set [ find default-name=ether2 ] comment="Management port (untagged, out-of-band)"
/interface wireless manual-tx-power-table
set wlan1 comment="2.4 GHz radio"
set wlan2 comment="5 GHz radio"
/interface wireless nstreme
/interface vlan
add comment="SVI for VLAN20" interface=br-vlan name=vlan20 vlan-id=20
add comment="SVI for VLAN30" interface=br-vlan name=vlan30 vlan-id=30
set [ find default=yes ] authentication-types=wpa2-psk comment="WPA2/WPA3 for default profile" disable-pmkid=yes mode=dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=my-secure-password1
add authentication-types=wpa2-psk comment="WPA2/WPA3 for myssid-base-local" disable-pmkid=yes mode=dynamic-keys name=profile-vlan20 supplicant-identity=MikroTik wpa2-pre-shared-key=my-secure-password2
add authentication-types=wpa2-psk comment="WPA2/WPA3 for myssid-base-guest" disable-pmkid=yes mode=dynamic-keys name=profile-vlan30 supplicant-identity=MikroTik wpa2-pre-shared-key=my-secure-password3
/interface wireless
add comment="2.4GHz VLAN20 SSID" disabled=no mac-address=06:F4:1C:27:48:42 master-interface=wlan1 name=wlan20-2ghz security-profile=profile-vlan20 ssid=myssid-base-local vlan-id=20
add comment="5GHz VLAN20 SSID" disabled=no mac-address=06:F4:1C:27:48:44 master-interface=wlan2 name=wlan20-5ghz security-profile=profile-vlan20 ssid=myssid-base-local vlan-id=20
add comment="2.4GHz VLAN30 SSID" disabled=no mac-address=06:F4:1C:27:48:43 master-interface=wlan1 name=wlan30-2ghz security-profile=profile-vlan30 ssid=myssid-base-guest vlan-id=30
add comment="5GHz VLAN30 SSID" disabled=no mac-address=06:F4:1C:27:48:45 master-interface=wlan2 name=wlan30-5ghz security-profile=profile-vlan30 ssid=myssid-base-guest vlan-id=30
set wlan20-2ghz comment="2.4GHz VLAN20 SSID"
set wlan20-5ghz comment="5GHz VLAN20 SSID"
set wlan30-2ghz comment="2.4GHz VLAN30 SSID"
set wlan30-5ghz comment="5GHz VLAN30 SSID"
set *8 comment="2.4GHz VLAN20 SSID"
set *A comment="5GHz VLAN20 SSID"
set *9 comment="2.4GHz VLAN30 SSID"
set *B comment="5GHz VLAN30 SSID"
/ip hotspot profile
add bridge=br-vlan comment="WAN trunk - tagged VLAN20,30" interface=ether1 pvid=20
add bridge=br-vlan comment="VLAN20 (Trusted LAN)" tagged=br-vlan,ether1 untagged=wlan20-2ghz,wlan20-5ghz vlan-ids=20
add bridge=br-vlan comment="VLAN30 (Guest)" tagged=br-vlan,ether1 untagged=wlan30-2ghz,wlan30-5ghz vlan-ids=30
add address=192.168.100.50/24 comment="Management port static IP" interface=ether2 network=192.168.100.0
add address=192.168.20.2/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.2/24 interface=vlan30 network=192.168.30.0
add action=accept chain=input comment="Allow established" connection-state=established,related
add action=accept chain=input comment="Allow ICMP (ping)" protocol=icmp
add action=accept chain=input comment="Allow WinBox" dst-port=8291 protocol=tcp
add action=accept chain=input comment="Allow SSH" dst-port=22 protocol=tcp
add action=accept chain=forward comment="Allow forward established" connection-state=established,related
add action=accept chain=forward comment="Allow all forward (router handles security)"
/ip service
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
/system ntp client
set enabled=yes primary-ntp=172.104.154.182 secondary-ntp=131.188.3.223
