Accidentally disabled ethernet interface
Today I accidentally disabled my ethernet interface. After I did that, my internet went down and I was no longer able to connect with WinBox or HTTP. Please help me, I’m pretty new to this internet stuff…
Use other interface to log in or reset the device.
The problem is that when I connect to other ethernet cable the effect is the same. I still cannot connect…
Give us a little more detail. I’m making an assumption that this router has one internet “WAN” connection, and multiple local LAN connections. Assuming this is the case, is this a router at a remote location that you are accessing via the internet, and you disabled the internet connection?
If that’s the case, your only option is to go to the location, and use computer connected to a LAN port and connect to the router and re-enable the internet connection. If my assumptions are incorrect, please give us more detail of the situation so we can help you.
My problem is that I can’t access router and internet connection
  1. Are you at the location where the router is located or trying to access it remotely via the internet?
  2. Is my assumption in my first response correct about your general configuration? If NOT, give us details.
  3. If you are local, are you attempting to access the router with a computer connected to a local LAN port, or the WAN port?
We can’t help you if you don’t give us details. Don’t assume we know your configuration - we can only guess if you don’t tell us.
One more question - what hardware are you using?
