Hi everyone,
(To get to the point, see the TLDR at the end of the post.)
I am a massive networking noob, so I got the routerboard hAP ac lite to play with. I am using Windows 10 on my PC.
I was trying to configure dhcp and failing miserably, but i did notice that I had quite old firmware version ( 6.40.8 ). I also noticed that the WinBox was demanding that I use “legacy mode” to connect to it.
I googled around, and learned that apparently the way to stop using “legacy mode” is to update router-os. So I went to this guide:
https://wiki.mikrotik.com/wiki/Manual:Upgrading_RouterOS
So I downloaded RouterOS for mipsbe, version 6.47.1 (stable) from here: https://mikrotik.com/download
I also downloaded the “extra packages”.
- Then I connected to my Routerboard with FileZilla (as in guide).
Then I drag and dropped the Router OS npk, and all the extra npk’s into the root directory of the RouterBoard FTP server.
Then I powercycled it.
Since then, it seems to have been bricked. I then went to the netinstall method as described here:
https://wiki.mikrotik.com/wiki/Manual:Netinstall
This actually went apparently sucessfully: I did the thing where you hold “reset” until the “user” light turns off, connect the routerboard directly to my PC and then netinstall found the device. I gave the netinstall tool my routeros binary, and pressed “install”. The “install” button greyed out for a few seconds, and then became press-able again, from which I understand it sucessfully installed.
However, after power cycling the exact same bricked-like behaviour persisted. By which I mean, when I plug in the ethernet cable directly from my PC to the routerboard, my network adapters window flashes between “initalizing interface… Ethernet cable unplugged… initializing interface… Ethernet cable unplugged…”, etc. The indicator lights on the RouterBoard for the ethernet ports remain completely off, no sign of any activity.
So, at this stage I decided to crack the thing open. Hoping for a physical serial port, I didn’t find one (hopefully someone can confirm.) There’s a jtag debug header but I doubt I can reprogram the flash from it. I did, however, find a “W25Q128JVSM”, which is where I imagine all the binaries live?
TLDR:
So, I am thinking, I have a flash programmer, all I need to do is desolder it and re-flash it with a sane default. Can someone provide an official flash image for the MicroTik hAP ac lite? Heres the specific model: https://mikrotik.com/product/RB952Ui-5ac2nD
