Accidently, I removed Interface ether1.
Accidently, I removed Interface ether1 and I am disconnected. Now not show MAC & IP address in WinBox with ethernet cable/console. Also try to connect other interfaces like (Eth02, Eth03, Eth04, and Eth05). But the problem not solved. In this situation, What can I do now?
What kind of device do you have (model)?
How did you remove the interface ?
Is that even possible Normis? To remove the ethernet interface itself?
One would possibly assume accidentally removed it from the default bridge - which is why the device model is important - might be best to factory reset the device.
Yes. Every model has this feature. All you need is a chisel or big screwdriver. Apply lot of pressure on the port and the interface will come off.
I am pretty sure Normis is trying to understand what OP actually means same as everyone else, because “remove ethernet interface” is quite ambiguous
it’s actually RB750G & a logical issue…
continue trying & After long time i can access from(ETH02,ETH03,ETH04,ETH05).
Actually, what happened I don’t understand…
