Accounting - ip.cgi not found??
Hi there!
I have a couple of 2.9ers (x86 and RB) running and accounting traffic, but last week I upgraded one of them (x86) to 3.0rc11 and it doesn’t work anymore :frowning:
Accounting is enabled, web access is enabled and even accessible from 0.0.0.0/0, take snapshot shows the traffic, but when I try to access it via web (http://routerip/accounting/ip.cgi) I get a NOT FOUND?!?!
Seems this has changed in 3.0??
I also tried it on a RB - exactly the same.
Does any1 know where I find the ip.cgi? :slight_smile:
Thanks,
uebi
PS: Not much in the forum and the 3.0 manual doesn’t cover it yet :frowning:
No reply? :frowning:
I really need accounting (or more specifically the accounting web access) to be running until tomorrow and I hope that downgrading to 2.9 isn’t the only solution…
I’m sure that somebody out there knows the “new url” to ip.cgi, but why don’t you tell me? Do you hate me? :wink:
Thanks,
uebi
The problem is with Winbox matcher ‘web-access’ yes/no.
It does not seems to work, however you can enable it from console,
‘ip accounting web-access set accessible-via-web=yes’.
Then it should work fine, Winbox matcher should be fixed in the upcoming versions.
Woohoo, works like a charm! :slight_smile:
I have to admit that I never looked there, I thought the path might have changed in 3.0 and never checked via the CLI if the enable takes effect duck
THANK YOU SO MUCH!
Greets,
uebi
