I have configured hAPLite to use hotspot via radius server with accounting. However the mikrotik is sending wrong accounting data. ie its sending only 220KB even after downloading 100MB from internet.
Tried a bunch of versions as well namely 6.41rc, 6.40.3
yes you shuld disable the fasttrack from firewall filter , then reboot your routerboard
you will find 3 or 2 filter for fasttrack in firewall filter, just disable or remove it
if you need fasttrack for any work like server cash or anything you can limit it for an ip address or an interface
