Accounting seems to be broken in 6.35.2
Home setup, no hotspot, hP ac Lite.
/ip accounting used to correctly report usage in 6.34.3
After upgrade to 6.35.2 accounting still spits out some numbers but they are very small (even when the actual traffic is big).
In the change log for 6.35 we can see:
*) l2tp & pppoe - fixed user traffic accounting when fastpath was used;
I’m using pppoe, and something was changed in this area. Did I need to configure accounting differently when I’m on 6.35.
The old behaviour was very accurate, I compared the numbers from the router accounting with ones captured on local PC and they were the same.
Does anyone know what exactly this fix was, and what do I need to change to get the accounting working again (short of downgrading)?
Reverting back to 6.34.3 fixes the issue.
