Accounting software that integrates with Hotspot
Hi guys,
I am trying to create hotspot pages that allows users to sign up for accounts with a credit card. I want the Radius entries to be created in Freeradius (easy), and the user to be online immediately. The problem I am having is that I also want accounting software that gets this information.
What accounting software do you guys use for your wisp? Is there any software that has easy integration and 3rd party software support through an SDK or API?
Try radius from dmasoftlab
If you wanted to build your own solution, then Kashflow is a web based accounts package with an excellent API that allows you to raise invoices and send them via API.
