Acess Local network
Dear Mikrotik Team,
My name nara, i live in cambodia, i have one mikrotik routerboard 750GL and i made it as hotspot
i connect port1(192.168.101.1) to my local network and port2 is hotspot and dhcp range 192.168.168.2…
i have access point inside the hotspot, mean the ip of access point is the same range of hotspot eg: 192.168.168.23
so how can i do if i want to access to configure my access point if i staying in the network 192.168.101.0
thank in advance :slight_smile:
Can you show me a screenshot of your routing table, your ip address table and your interface table?
Thanks!
Before you will be able to access it, you need to bypass that ip.
/ip hotspot ip-binding
add address=192.168.168.23 type=bypassed
After that, it depends on the routing in the gateway router for the 192.168.101.x localnet.
Thank so much for your kind, i will try :slight_smile:
here is please help to check
why no one help me:(
