acess to standard wireless router
Hi
I have a aheros AR5213 that I was using a wireless connection to a WAN network
I have now moved house and cannot get a connection on the wan. My neighbour has allowed me to use her standard wireless internet connection. I was wondering if I could use the unit to connect. I can get a signal but cannot figure out how to load the password in to make the connection. Can you help me with this?
Many thanks
Paul Kelly
what is the problem exactly, please tell us what model of MikroTik hardware do you use, and which part of configuration is the problem. Show us a picture (screenshot) of the issue if possible.
I live in rural Ireland where there is no available land line broadband,. And mobile internet does not reach. My landlord who lives about 500 meters from me has a broadband connection which he says I can share
I have a MikroTik Routerboard 153 (Level 4) WISP AP. I can use the scan and pick up a good signal from his domestic wireless router. But it will not let me connect because it is password protected (which I have)
Is there a way to load the password into to the Routerboard so it will connect to the domestic wireless router
Hope this clarifies the problem
Thanks for all your help
yes, you need to find out if that’s a WEP or WPA password, and then configure your security profile accordingly. here is how:
http://forum.mikrotik.com/t/wep-not-available-in-rb433ah-r52h-card/33768/6
Brilliant I’ll try that
Thanks for all the help
I Followed the last post and now have the landlords wireless router on the status and everything there looks O K. but it wont let me out onto the internet. I’ve chatted to a friend and he suggested it might be the I.P setting on the firewall of the my routerbox. I have set the NAT to masquerade but this has had no effect
I’ve a feeling that this is a little over my head and might need to seek someone who knows about this trickery to come and look at it for me but just thought you might be able too suggest where I might look and you might have some thread that you can send me to fix the problem
I realise it’s a long shot but would appreciate any suggestions you can offer
Thanks for all the help.
Paul Kelly
nat.doc (167 KB)
Can you ping out to the net from a “New Terminal” window on the RB ?
My suggestion would be ditch the masquerade and keep it simple. Create a bridge with the wireless port and the Ethernet interface that you are using and then if all goes well, you should pull an address from the other router and you are done. :smiley:
Hi have been away working and have been using a wireless doggle to connect to the landladies router. But it is only barely getting a signal and keeps breaking down so I’m back trying to get the router box up and running. So sorry it’s been so long and thanks for all the help up to now
In answer to the question no I cant ping out onto the net or ping the wireless router
I am researching connecting using a bridge and when I’ve figured how to set this up I’ll try it and let you know if that works
Paul
Could not get the bridge to work
Also cannot ping out to the web from a new terminal window but can ping the router box
Sorry for the delay but any further help would be grateful
i am having a similar problem, I got ip from modem but no internet.
I’ve got a little closer with this can now ping out too the Micro tik router and ping the landlords wireless router but still no Internet. Did this by adding the wireless routers IP to the list in Winbox
Paul
Can anyone give me instructions on how to set up the bridge as suggested by hazyd and I will see if that works
I have had help from a friend and have now got the microic router pingng out onto the web. It has been assigned an IP address 192.168.1.144/24 And seems to be working fine.
The problem now is that my computer has an ip of 169.254.213.152 and when I ping out onto the wed I get a general failure. This I think is a problem with the microtic not assigning the correct Ip
Can anyone help
see if ur landlord router has dhcp enabled or u need to know the IP series being used in the LAN port & use ip from same pool on ur PC
The dhcp is enabled and I have tried to put the settings into ipv4 using 198.162.1.155 this is In the range also the dns server used by the landladys router but with no joy.
