I am trying to get the FreeACS working with TR069 client protocol on the mikrotik. Every time I try and send a TR069_Script job to the mikrotik it resets the mikrotik to default. All I am trying to do at this point is just get it to rename the identity is there something I am missing? I save this /system identity set name=test5 as a .alter file to upload.
Also I have noticed that after a reboot my change has been made. So it gets pushed I just dont want the router reset during it.
So got it working probably stupid oversight on my part but after rereading and reading what normis had posted elsewhere figured it out. Under files scripts you need to make sure you are saving it with the name ext .alter. After I figured that out FreeAcs s working like a champ for what I needed.
