Short story:
There is no way to set-routing-mark in ROS v7 routing filters.
Long story:
We’ve got 2 edge routers with eBGP connections to the Internet. Each router is only receiving the default route from the provider. We need to redistribute the default route from each router to the other router using iBGP and place the received default route to a custom route table, so we can use it for policy routing.
In ROS v6 this can be done by setting originate-default to if-installed and by set-routing-mark action in routing filters for the iBGP, but we were unable to achieve the same in ROS v7. There is the rtab property in ROS v7 routing filters, but unfortunately, it is readonly.
