Activate wps
in /interface wireless print I don’t see wps-mode listed. How do I, temporarily, activate wps?
RouterOS 6.46.7 / Mikrotik hAP
In Winbox, under wireless tab, there is a button “WPS accept”, press that one.
(assuming you allow WPS for the interface).
Make sure you press the “advanced mode” first to see WPS parameters.
Some routerboards also have a button or joint wps/reset button one can use…
clicking WPS accept seems to do nothing.
Where is “advanced mode”?
Found the advanced options.
I can only specify an SSID.Will it find the WPA2 PSK automatically?
WPA2-PSK etc.. settings can be found within the wireless security profile. If you’re creating a new one, set it afterwards on the wireless interface as well.
