Device: rb433gl, ros 6.7, 2x wlan.
I’m trying to setup a wlan on microtik so that users will use their username/password in AD to connect.
I’ve got to the point where computers that are members of the domain (and has a certificate from the domain installed) will connect using the certificate and not ask for username/password. But I want this to work with computers/mobiles that are not members of the domain. I want them to type in their (domainname/)username/password.
I’ve got it working on a cisco AP using this guide:
http://jackstromberg.com/2013/05/tutorial-802-1x-authentication-via-wifi-active-directory-network-policy-server-cisco-wlan-group-policy/
As it works on the cisco and not on the mikrotik I guess the radius server is setup correctly, and I think there must be something in the cisco config that I’ve missed when trying to do the same in mikrotik.
Here is what I have on the running config, the one that (unintentionally) works with domain certificate authentication, but not with (domain/)username/password authentication.
/radius
add address=10.61.6.55 secret=password service=ppp,login,wireless src-address=10.61.6.216
add authentication-types=wpa-eap,wpa2-eap mode=dynamic-keys name="WIFIradius" radius-eap-accounting=yes radius-mac-mode=as-username-and-password supplicant-identity="WIFI216" tls-mode=dont-verify-certificate
/interface wireless
add disabled=no l2mtu=2290 mac-address=02:0C:42:6C:B8:AA master-interface=wlan1 name=C-WIFI security-profile="WIFIradius" ssid=testWIFI wds-cost-range=0 wds-default-cost=0
When using domain\user and password to connect from a pc not member of the domain, the radius server denies access logging the following:
Reason Code: 265
Reason: The certificate chain was issued by an authority that is not trusted.
So it seems like the mikrotik sends some kind of certificate to the radius server, and not the username/password.
Which setting am I missing?
