Hi! I’m just a noob with mk. I have a RB4011iGS+RM .
I’m trying to run this config but I think it’s a bit old a it shows some error.
Could someone, please, guide me? It’s so important, thanks in advance!
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
/interface vlan
add interface=ether1-gateway l2mtu=1594 name=vlan1 vlan-id=100
add address-pool=default-dhcp disabled=no interface=ether2-master-local name=\
default
add address=192.168.88.1/24 comment="default configuration" interface=\
ether2-master-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no \
interface=vlan1
add address=192.168.88.0/24 comment="default configuration" gateway=\
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
established,related
add chain=input comment=webfig dst-port=81 in-interface=vlan1 protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=vlan1
add action=fasttrack-connection chain=forward comment="default configuration" \
add chain=forward comment="default configuration" connection-state=\
established,related
add action=drop chain=forward comment="default configuration" connection-state=\
invalid
add action=drop chain=forward comment="default configuration" \
connection-nat-state=!dstnat connection-state=new in-interface=vlan1
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=vlan1
/system package update
set channel=current
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
/tool mac-server mac-winbox
/tool romon port
add
