Add 2 APs to RB3011
I actually have a RB3011 to manage the network at home. I have a OpenWRT device as AP but it doesn’t work very well, it has bad signal.
I want to add 2 Mikrotik APs to cover all rooms. My questions:
  1. Is it possible to manage both APs from the RB3011?
  2. Is it possible to get real roaming for wireless clients? I use Skype and Whatapp voip at home.
  3. I have wired all the rooms, I want to use PoE devices if possible. Which devices do you recomend?
Best regards.
in my opinion.
wAP or wAP ac + CAPsMAN + proper configuration = everything you want
Thanks!
Will roaming work?
Kind regards.
